connect my android
  • 28 views
  • Last reply by Paul
Can't find "sync and save data " on my android.
Attached screenshots
Hi
If you are signed into your Mozilla Account, the option that you are looking for in the Firefox for Android menu is "Account info".
I hope that this helps.
